help removing stabilizer bar link
mygsx2120
353
Jan 4, 2006
Newark, Ohio
I am trying to install tokico adjustables/spring and can't seem to remove the stabilizer bar links. My wrench that is holding it in place keeps spinning. I have rounded off most of the edges and bloodied half of my knuckles. I know it should not be this hard. The VFAQ says to pull it to one side to prevent the bolt from spinning, but no matter how hard I pull, it still spins. Anyone have an easy solution, or for that matter any solution. Thank you.
or
If you're careful you may cut off just the nut.
If you're careful you may cut off just the nut.[/QUOTE]
I held it in place with a vice grip and cut it off with a dremel...cuty our loss's and put a new one in anyways.
I don't know what they look like, but usually if you put some weight on them or bind them up, it does the trick.
