Help Removing Banjo Bolt from Fuel Filter on a 420a
Zoned
Jan 18, 2014
Napa, California
How on earth do you remove the banjo bolt from the fuel filter on a 420a?! There's no clearance for a socket wrench and I can't find a wrench that sits flush on the bolt. They all end up butting up against the bracket that holds the bolt. Do you need a special wrench to remove it?
Thanks for the link. It's still impossible for me to get that bolt to move. Hopefully letting PB Blaster saturate it overnight will help some.
    • Sdcryan1
