Fuel Leak from Banjo Bolt = No Start?
solisjulian
82
Jan 5, 2013
wooddale, Illinois
Hello, thank you for viewing.
i had a quick question.
would a small leak from the banjo bolt on the fuel filter cause a no start??:confused::confused:
How much of a leak if your not getting enough fuel that could be a problem, bud do you have spark, and compression? Rule those out and back to the fuel issue. I had leaks In my fuel lines but car still stared up.
the top of the filter and around it gets soaked with fuel. it wants to start on the first crank but dosent
would that cause it no to start?
Thanks ! appreciate the help.
hello thanks for viewing my post
i have a 1g eagle talon that has been experiencing hard starts
i have recently changed
- coolant temp sensor
- mass air flow sensor
What else could be causeing this i havent worked on dsm much so if you guys can please help me find the cause id appreciate it thanks!:thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
