help quick! brake booster hose question
TheGreatGSX
133
Dec 27, 2008
Morgantown, West Virginia
Will a 1g brake booster hose w/ check valve work on a 2g?
Nobody?
I know the lengths are a little different and also the bend in the hose is a little different as well, I just wanted to know if I could make it work and wondered if there was any difference between the check valves from the 1g and 2g.
The hose does not matter any booster hose will do. If you have already removed the check valve you are probably screwed and will need another booster. You can replacethem but you cannot operate the brakes with it out. Just buy the valve new an old one is a waste of time.
