help out on fuel
red_gsx
145
Aug 18, 2004
Rockville, Maryland
hey im not exactly new to dsm's but this question might seem quite stupid to alot of people. anyways i just bought a t-28 for my 97 gsx and am now working up the fuel system on the car. now the safc and fuel pressure regulator , do i need both? i keep hearing get the safc, get the safc but fuel is not something ive studied up on too much yet. basically if you could advise me a little here. do i absolutely need a fuel pump and injectors? i heard the stocks are 450cc and should be able to hold for a t-28. and the safc and fpr, do i need both or what? just for reference its the b&m command flo with the gauge. thanks for everything
Well heres what I would recommend, get a fuel pump, 190 should do you good if your not gonna go bigger down the road; pick up some 550 injectors. With the upgraded fuel pump you WILL need the afpr to set a base pressure on the fuel. You will also need the SAFC to "tune" how much those bigger injector deliver at certain rpm points. Hope it helps and good luck :thumb:
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
