help no spark 2 cylinders
rebuild101
Sep 28, 2004
oak park, Michigan
95 talon tsi FWD 3in gm maf and new piping took car to acr wash did under hood no big deal was drying and figured better turn it off so i dont cut mu fingers off in cam gears after dry went to start and started but shakes real bad and thn died many attemps all failed timing is fine, fuel is fine but spark only on 2,3 cylinders the power transistor is fine and we dont know what to do i need major help:cry:
So, this means it ran good before you pressure washed the engine? If so, then start pulling your plug wires and using compressed air, start drying them. Do not spray pressurized water on your ignition system. You've probably drowned out the engine.
Start cleaning your connections and keep it up till it runs.
If this is not the case, post a little clearer what you need.
Good Luck
we took all the plugs out they are fine and the wires are dry we think that it might be the cas because it is the last thing left to check because we were to lazy to take the cover off at night so we need to check that today but has anyone ever heard of anything like this possible if the translator is bad or if maybe the ecu that would only make one coil pack work and not the other
so for all of you that wondered what the problem was i tore down the entire side of the engine and found tha cam position sensor was broke in half. all i can say is that when the towel snagged in there it broke the sensor but will get it fixed today and hope it will run :talon: keep it posted
