HELP-no dash lights
94custtal
Jan 19, 2005
McDermott, Ohio
Ok, maybe you guys can help me out. None of my dash lights are working, i've checked the fuse box and there is nothing wrong.I have aftermarket reverse glow gauges that worked up until a few days ago hooked up to my park lights. My park lights are also non working.....is there a fusable link somwhere behind the dash that I looked over or what else could it be? :( plz help
got the same issue......my tailight fuse keeps blowing ............ did everything to find short...........all that is not working
tailights
dash lights
parking lights
LET ME KNOW WHEN YOU FIND OUT SOMETHING.................PLEASE!!!!!!!!!!!
THKS
tailights
dash lights
parking lights
THKS
either of you install a head unit recently?
Often the wire marked Illumination is a ground when it should be hot, or vice versa.
I had the same issue in my 3/S and it was the illum wire. I traced it down as best as I could, but happened onto it by chance one day.
If not that, then keep looking :)
sorry 4 puting this in the wrong area posted this morning b4 heading 2 school.....ive had the same head unit 4 goin on a year and havnt recently done anything 2 my dash. is there any fuses hidin out of sight i might be lookin over?at first i thought it was just my dash lights and i said no biggie, i have neons i can see by- but my gf's father brought 2 my attention i had no tailights either... thats what im worried about
It sounds like you just got a short to ground somewhere, which SHOULD obviously blow a fuse. Replace the fuse with a known good one anyway. I know fuses are supposed to separate violently when they blow but I've had ones that blew and have had hairline separations that looked fine but didn't test out on a voltmeter. Before you go turning on the lights again though, take out the entire indiglo assembly and replace the fuse. If everything works, start over with the wiring, it'll be easier than probing parts of the line trying to find a ground short in my opinion.
If your headlights work, no parking lights and no dash lights; check the tail light relay in the underhood fuse box. I had the same problem and it was my tail light relay that was the problem. Hope this helps.
