Help! New built motor, bad oil pressure! :(
way2slowtalon
147
Oct 24, 2004
Newington, Connecticut
6 bolt (92)
Wiseco pistons
Eagle Rods
NEW OEM oil pump
NEW OEM oil filter housing
Balance Shaft Eliminated
Running straight 40 weight oil, and 1 lucas!
I have 60 psi when cold starting, and I am fine untill the car warms up. Than we have oil pressure at 7-12psi. What else can be checked, or what could the problem?
Thanks
You don't seem to be too far from normal. I would get that Lucas out of there and go to some good 10w30 oil. 40 wt can get a little fudgy if it is cool out. Thinner oil, especially synthetic will give you better lubrication upon startup which is where the most wear on your motor happens.
Regards
Greg
^ That. Also what oil filter are you using? Strange things have happened in the past with oil filters. . .
You did flip your balence shaft bearings so that they block that oil galley right?
Yup machine shop that did the Bearings, also did balance shaft removal, and guarantee both are done perfect.
Also used 2 diff oil filters, Fram and Mobil same exact issue with pressure.
After warmed up dummy light will go on at idle, and will go off when given a little gas. The light goes on at what.... 5 psi?!
6 bolt (92)
Wiseco pistons
Eagle Rods
NEW OEM oil pump
Thanks
Isn't 7-10psi per thousand the rule of thumb after car warms up?... At least thats what I've been reading...so you should be fine ...
