Help!! Need Turbo Help
Corradokng
Sep 9, 2005
Richfield, Minnesota
OK. Heres my story, bought a 94 Mitsubishi galant from some old lady. It has the 2.4 4Cyl. I recently replaced a motor on a 95 eclipse turbo and had an extra stock turbo laying around. So I said what the hell, Why not turbo this galant.
I have bolted on my turbo, I got the trusty plasma cutter and made a down pipe and some boost tubes. I used an extra intercooler i had from my corrado. Now to the point. Not sure if anyone knows specs on this motor. I am curious what stock compression ratio is. How much boost can I run on this motor. will the maf, injectors, and fuel pump be able to keep up. I have a air/fuel gauge and understand cars so i won`t lean it out. but am curios what size turbo a stock 2g is. any help would be great. i understand this site is primarly geared towards dsms. But what the hell gotta have a little fun once and awhile. so Far I only have about 40$ into this setup.
One last thing does anyone know where I can get a turbo rebuild kit for a stock 2G Garret Turbo?
would the compressor fittings be in the same spot? I Already spent a bunch of time making boost tubes. I also would not be paying for a rebuild, I just need the seals and bearing I would rebuild it myself.
ok, figured out what kind of turbo, got my rebuild kit. put the turbo together, working good. I am only running 5psi of boost now, not sure what this motor can take. anyone know what kind of boost I can run before I have issues? will injectors from a 2G fit, is it even worth it, or not much difference. I have a inline pump laying around I might throw in if needed. Still wondering if anyone knows compression ration and stock hp. Its your basicn 2.4 galant Sohc. Any help would be great. Also is it possible to wire up a gm maf, or a maf from anything else. trying to find something round instead of oval. Thanks in advance.
