Help! My car just turned off!
ibbivibbi
Mar 24, 2004
Iceland, Europe
Hello.
Yesterday, while driving my car it just turned off and will not start up again! The Check Engine light came on and I read it and it gives code 22 which appears to be the crankshaft postition sensor.
Car is Talon Tsi ´1993
Could it be something else ?
What do I need to check?
Where is this Crankshaft position sensor?
Can somebody help me! please!
:cry:
Wow, I just had the same thing happen to me. Everyone has been telling me that my it may of jumped timing, but I checked it and it seems to be alright. My next guess is the crankshaft sensor. So if you find anything out, then let me know and i will do the same for you.
Good luck.
Your CAS (cam/crank angle sensor) is located on the leftside of the motor, in the intake cam, by your throttle body. It has a plug, and is bolted down by two nuts. Check to see if you are getting spark before replacing it, if the CAS is bad, you won't get spark
