Help me with my vacuum problem please!
blackrosenova40
398
4
Jan 12, 2006
Belle Plaine, Minnesota
A couple of days ago I installed a used 14b turbo into my car because my old one was shot. It boosts great and holds perfectly to 14 psi. Idle vaccum reads 19-20 inches and decelaration vacuum usually read 24. Just today as I left school I noticed it was pulling less vacuum during decelarating.
For example if I brought the engine up to 6000 and let go it will not pull more than 20!
But if I bring it down to say 2000 and then decelarate it will pull pretty close to 24.
Anybody have any clue whats going on? My idle is fine and im running a maft pro using a Map sensor and ait sensor.
My guess is theres a leak from the intake manifold (vaccum lines coming from the intake or throttle body gasket, or intake gasket or fuel injector seals). Or my sencond guess is an exhaust restriction.
Do a boost leak test. It will identify any vacuum leaks. If you had an exhaust restriction severe enough to affect intake vacuum then I would think that your car would barely even be running.
The o.d. of the compressor inlet on a 16G is 58mm (2.28"). The 14b has a slightly smaller inlet although I forget the exact o.d. But a 2" coupler should work fine for the tester if that's what you're getting at.
Yeah, you can always use one a little bigger. I use the stock intake ring that goes around the turbo in my boost leak tester to fill the gap.
