2G Help finding awd rear hub only
plow420
Feb 15, 2009
breckenridge, Minnesota
I had the axles seize to the rear hubs and have been trying to get the axle out with a 7 ton puller with no success. I bought new wheel bearings (timken) but they dont come with the hub with the wheel studs. I messed up the rear hub trying to get the axle out. Where can you get a 2g awd rear hub only without the wheel bearing.
I found that jnz has both the hub and wheel bearing, but I already bought wheel bearings.
I called napa/ others and no one can fine rear hubs for my car.
Can anyone find me a place to buy new rear wheel hubs.
You know that you can get them from JNZ. Extremepsi has them as well. This is ONLY available as a whole unit from Mitsubishi. If it is that big of a deal, return what you have already purchased. I have had success soaking the splines with PB blaster or Kroil (works better). I let it soak for a couple days with frequent re-application. You would have more access if you pulled the axle and spindle as a whole. Sometime heat is involved. Sometimes there is no saving the axle, and need to find a replacement axle as well.
I have used a can of pb blaster, and a propane torch for an hour. Only got the spindle up to 700 degrees. Still no budging it.
I pulled the whole unit now and looking for someone with a large press to get it out.
Looks like I'm going to have to return the bearings and get oem.
