1G AWD REAR HUB.
Ghost_92TSi
1,046
Aug 18, 2009
El Paso, Texas
The other day I was removing my wheel and my stud spun it its place. I was looking for a replacement so I can just use 5 new studs. I fear the other 3 on the wheel will start to spin too. I can't find a rear AWD one anywhere. Just a bunch for FWD with no axle hook up. Can someone point me in the right direction?
I would try replacing the stud first too before changing the hub. You might have to replace the hub if the holes are too damaged and don't hold the new stud in place.
Or if the new stud spins, you can always go to the parts store and get studs that have 1/16 bigger knurl with the same thread and try to fit that. Might have to slightly enlarge the hole but I don't see why it wouldn't work. Most part stores have a big selection of those studs, just tell them length, thread and knurl size that's needed
