help diagnose my problem (smoke, turbo maybe?)
andymac40330
177
Sep 4, 2007
Harrodsburg, Kentucky
Ok so I'm driving along today (first time I've had my car out this week) and i start to get on it just a little bit and i get this wierd sound from my turbo. It has never made this sound before but it kind of bucket a little and when I went to full throttle it took off like normal up until a certain point. At this time I also noticed a little bit of white smoke coming from my exhaust (a little bit at idle, a little bit more under boost). Now, I am wondering if this sounds like a turbo issue to you guys or something else? Also (which may be irrelevant) my clutch shakes a little at pretty high rpms but doesn't effect the drivability or anything (no slipping, jerking nothing like that). Let me know what you guys think. Thanks in advance.
Check your turbo for shaft play. Take off the intake hose, try to wiggle the compressor wheel, up, down, in , out. etc.
yea i'll try that stuff, I had it boost leak tested about a month ago and everything was good, i actually have a hx-35 waiting to be installed (once i get all the support ready) and i was just hoping i hadn't messed anything up while i'm prepping it for the holset.
