Help diagnoase, video included!
darkiller_666
477
Feb 19, 2008
Salina, Kansas
I have been having problems getting my talon started after a recent problem with my coil pack and PTU! I decided i would go and take a video of how it was cranking to see if i get get some help and lo and behold the talon starts for the first time in like a month and a half. It would start only if i floored the gas as i crank it. It started but mad a horrible sound accompanied by some smoke. It did start and I am super happy about my progress. I went through every wire from the ecu and made sure all connections were good and electric taped them all up. I checked all the wires coming from the PTU, injectors, o2 sensors, the CPS, the fuse box, and any other wire i could find. Brand new plug wires and plugs. I new known working PTU! So please check out the video and help me if you can! greatly appreciated i cant wait to feel the boost again.
YouTube - MOV00689.MPG
Ok well tomarrow i plan on checking the wires from injectors back. Is there a way to check it with a multimeter? Like I said it sounds like the wires are shorting somewhere but I couldnt narrow it down. Im gunna try switching the injectors around to check and see if they work in reverse order.
make sure your spark plug wires are not crossed but parallel, this would cause the wires to short out, do you have a scan tool where you can read live data?
I dont have any scan tools. But from the videos you can tell there is spark in the first two cylinders. I tried switching the two around and it didnt help any. I tried changing the plug wires in all sorts of different orders. The way it is now is the only way it will idle on its own and run without hitting gas. Does anyone know how to check if the injectors are getting a good signal?
IT CANT HURT TO TRY
ok if you take a aaa bat. and run leads from pos and negative to your injector while its out and it should open and close make shure ## blowing threw it u will allso hear it i did this and it works to to tell if they open and close or not
I plan on switching the injectors from 1and2 to 3and4 and see if the other cylinders will fire with injectors traded out. that should let me know if it is the injectors or wiring/ecu problem
PM sent to you Myturbo
yes there 450cc i have a wireing harnest with an safc wired in so its all plug in play let me know if it would help
I have tried several PTU's. I took the fuel rail off today and turned the car over. There is fuel coming out of the injectors. I know i have spark, i know i have fuel. Any more ideas? I did notice the wires coming out of the ecu have been hacked through before. I dont know if it had something hooked up or what. I tried cleaning it all up as much as possible. Is there any certain pin or wire i should check for continuity or just check in general that might cause this problem.
Your injector can be dripping & it will still deliver fuel. Doesn't mean they are getting power.
Dude you need to buy a service manual & check to see if your injectors are getting power.
you need a new motor.
sorry but maybe you ment 155 but it says 145 if you say your ecu harnest was all jacked i would fix it what kind of fuel pump and are you running do you have a regulator
who cares about his wing at least its not a honda hes driving try bein helpfull anyways
recheck ## timming
Big update. The good. MYTURBO drove a few hours to come and help me check out my car. We got it firing on all 4 cylinders!!!!! The bad... i have a blow head gasket. So tomorrow i will for the first time take the head of and have a look. Hopefully the head is still good. If not ill be spending the whole day putting on my new head. Going to have it decked and sandblasted and polished!
I am unsure to the exact reason. I put in new injectors and i went through a lot of wiring fixing odds and ends. The one thing i have learned about dsm's is that the fix to anything takes patience and never giving up.
