way2slowtalon
- 147
- 0
- Oct 24, 2004
Newington,
Connecticut
This is about my 98 Rs, I have the weirdest oil leak. 100% its oil. It is leaking on the start of my catalytic converter, making my car look like I'm doin a smoke show. I have used tracer dye to no help.
Only my drivers side get oil on it. What seals are anywhere near the back of the motor? Can this be a rear main seal, and how can I check this since tracer dye didn't help. Also if you look under the car after hard driving you will see the cat's first 2 bolt smoking from oil.
Thanks!
Thanks!
Passangers side?
