HELP !! Crankshaft End Play
QuikyX
Oct 22, 2004
Austin, Minnesota
Hey,
I just got done doing my trial assembly of my 6 bolt It had .07 of end play with New bearings and everything, the question is will my car be able to make any power for a while with this kind of end play its also awd and im running a used ACT 2600. Do any bearing companys make a larger flanged thrust bearing?
Thanks for all your help
Andy Hull
PS I did my research on here and couldnt find anything out
Hey,
Im sorry i forgot to add another zero in there its at .007 :confused: Hows that for a car thats going to be drove hard
Thanks
Andy
Set the thrust bearing, torque the bolts, put it all back together and drive. Only a lack of oil OMG or the crankwalk gods :mad: can stop you now.
Yea, I wouldn't worry too much. Just make sure that they oil is flowing and the pressure is normal. But just to be safe I'd reassemble and make sure the play is the same.
You should be fine though.
