HELP! Could this be the ignition switch?
phenyxTA
Jan 29, 2004
St. Louis, Missouri
On my way to work today my 92 GS-T started acting up. The buzzer came on while I was driving it. (the one that comes on when you open the door with the key inserted) Then the headlights started dimming and the tach needle started bouncing back and forth. This lasted all the way to work. Thge only time it would stop was when I depressed the clutch pedal. When I got to work and turned the car off the buzzing sound continued so I disconnected the - battery cable. Later I went out to start it up and nothing. All the dash lights were on and the battery had plenty of juice but it wouldn't even turn over. It has a new alternator, battery, and starter. Whatever is wrong has to be something linked to the tach, buzzer, headlights, and ignition. Any ideas? I'd appreciate any help.:cry:
  • Wanted 6 bolt NT water pipe
    • chrisman287
