help choosing between 2 blocks to use for my build
4g63turbo84
614
Dec 10, 2008
ocala, Florida
I got two 6 bolt blocks (one is a turbo block and the other one is a non turbo block) . If I use the non turbo block I will use forged internals, or I can use the turbo block but the only thing wrong with that block is that I don't have the main caps for that block, but I have a set of main caps but that means I will have to have the block lined honed....
If you are building the motor anyways you can use the non turbo block and save some money by not having to get the turbo block line honed, the only difference between the two blocks is the oil squirters on the turbo block.
One difference between the motors is that the turbo block has oil squiters and the N/T block does not. IF you go with forged internals then I would use the N/T block. I say this because when I had my motor build I got rid of the oil squirters to send more oil pressure to the bearings. They are not hard to block off on the turbo block, so it really doesn't matter what block you use.
