Help Cant mount Transfer case, Stripped threads in tranny~
A9DTSI
Aug 22, 2005
Cny, New York
Ok so this may not be a newbie question, but i cant post anywhere else and nothing came up on search. The previous owner of my 93 tsi managed to over tighten all 5 transfer case bolts, theads came out on the bolts. Is there anything i can do?? i was thinking heli-coil but ive never seen one that big?
Check with a mechanic or machine shop and see if they can get the helicoils for you. FWIW, the bottom bolt on my t-case is stripped. I just ran a long bolt straight through, stuck a nut on it and cut the bolt off flush since there is very little space between it and the support beam behind it.
Ill have to try that, i know i can get behind one of the rear bolts also, not to sure about the rest.
