cant find transfer case bolts
Hunter89
Nov 30, 2012
Modesto, California
I just bought a 92 laser rs awd turbo with no tranny. I bought one from cl for $300 with matching transfer case. I was getting ready to put everything back together to get it running but I have an issue. I have all the bolts, nuts, hardware, etc except for the 5 transfer case bolts (3 long, 2 short). I tried to get some from the dodge dealer, (no Mitsubishi in my area), they said they were discontinued. I even went to orchard supply to match them but the thread pitch is so fine they don't carry them. Can anyone please tell me where I could find these bolts? And how much. It's the only thing I need to get my car running. I can't wait to drive it! Thanks
ok, first Idea is to grab the bolts that hold the straight lower control arm on thw 2g, they are the same bolt diameter except 4mm longer. you can just grab a pair of washers and stack it on the bolt and you are golden. and for the shorter bolts you can grab the 2g, rear lower control arm mounting bolts, grab the long ones. and you will have your "home made kit" from the junkyard.
second option is to actually buy the bolt kit from jnz tuning here:
http://www.jnztuning.com/product_info.php?products_id=2486&osCsid=6ac63e4ced6b7beaa1a9be8f8288a5e7
check them out.
Doubt you'd want to buy them from the dealer even if they DID have them. They're $100 for the set of 5 bolts at my local Mitsu dealer. CRAZY.
