Shane2GSX
- 423
- 25
- Oct 13, 2005
Louisville,
Kentucky
In the midst of installing my new SBR 3500 clutch and XACT flywheel on my GSX, we ran into a little problem. Everything has went smoothly for the most part, and we're almost finished. The only problem is when removing the axles, my buddies seemed to think (against my wishes) they needed to hammer my axles out from the outside in to make things easier to get to. In the process, the threads got bent on the passenger side axle as you might imagine. Now we can't get the bolt to go back on, which is the only thing holding us up from finishing the install. We have tried rethreading the axle by heating it up with a small torch. No luck. We've tried using a small flat head screw driver and other various flat tools with a hammer to straighten the threads. No luck still. Got the idea to take it out all together and use a tool my buddy has (don't know what its called but it has a roller and it rethreads) to fix the threads, but we can't get the damn axle out no matter what we do. We even tried using thick steel against the axle with 2 c-clamps on both sides pressing it with a lot of force. Wouldn't budge. So at this point, we're thinking of cutting the axle itself with a demel since the bent threads are just at the beginning. Other than that we're stumped, anyone have any ideas/advice???
