Help ASAP: Turbochargers.com 2g 16g install (SS oil line question)
Wufei
560
21
Sep 4, 2004
Los Angeles, California
Hiya,
Running into some problems with taking off the oil feed line. I'm not sure whether the line in the turbochargers.com 2g install kit is the full line that runs to the oil filter housing. It's about 27".
Help!
Ok, figured out it goes a different (shorter) path than the stock line. Thanks!
The stock line bolts to the block and follows upward behind the turbo. As CanadianTSi said, it will reach just fine across the front of the turbo (between the turbo and the radiator) into the oil filter housing. For reference, I have a standard 24" line and it worked perfectly.
Hey thanks! It's all good now...except a P1400 CEL from I think all the oil the T-25 put out.
