Help Again On The Egt Probe
hottboost
273
May 17, 2006
Romney, West Virginia
What Size Drill Bit And Tap Should I Use With The Autometer Probe?? Also I Decided To Tap In O2 Housing, So Does Anyone Have A Pic Or Descripton Of Exactly Where In The O2. Thanks Guys, I Know Ive Been fulll Of Questions!!!!!!!!
Have you tried the vfaq.com site. they have all this type of stuff on there. Otherwise you should be able to find it on the autometer site.
If your adapter is 1/8" NPT you want to drill with a "R" sized drill bit as the preferred choice or if you don't have that 11/32" or 8.70mm will work as well. As for the tap, if its a 1/8" NPT adapter you will obviously will want to use a 1/8" NPT tap.
  • Wanted 6 bolt NT water pipe
    • chrisman287
