headlight warning beep
sublikwid
Jun 19, 2004
Greenfield, Wisconsin
hey all, so my beeper has never worked, when i leave my lights on when ign. is off, i wont know bc my warning does not work. is there a fuse or something i can check to see what is not working? i cant even remember how many times i left my lights on and drained the battery. thanks
Not early in the morning when you're late for class and when you arrive on campus, the light is already bright and you can't tell. :p
You can find a write up telling you how to disable this feature (in case someone did it in the past and you would like to un-do it or learn more about how it's done so you have some idea how to check the system) in the 2GNT wiki.
Here's the path to follow.
Cars \ Modifications \ Image \ Interior \ Illumination
i know that a couple lights do not work in my car, the keyring light and the lighter light. are these connected to the headlight warning buzzer
at night when you open your door, do your interior lights come on? If not your door switch is bad. Thats why my talon buzzer never worked.
Terry
it works on the driver side, but not the passenger. and even sometimes it doesn't work on the driver's side until i wiggle it a bit. any other ideas about how to fix the headlight warning chime. thanks
i have no idea where to look, i'll search and tell ya what i see
i looked and cant find the location of the buzzer?
