Head gasket replacement question
all gaskets on the head should be replaced, and definitely replace all the timing components while you're at it.
Head Gasket
Timing Belt
Auto Tensioner
Acc. Belts
Pulleys as needed
Intake and exhaust gaskets
Hell, while you're at it and the head is off...remove the cams... drop in some 3G lifters... pop off the valve springs.. replace the valve seals and polish the valves. ;D
