Head gasket question
Boostedexcel
133
Sep 22, 2005
hidden hills, California
Is it true that if I go .30 over on the cylinders, that I need a .40 over head gasket?
No.
As far as I've seen, almost all headgaskets will be ok until the bore gets larger than .040 over, at which point you're doing to have difficulty finding a set of pistons.
im asking becaue cometic only makes a head gaskets in .20 and .40 over and it doent seem that it would seal properly if the gasket wasnt the same size as the bore.
