HE351VE 3rd gear pull at 26 psi
blucas1984
47
Nov 20, 2008
west unity, Ohio
first 3rd gear pull with he351ve at 26 psi , i dont know if i like it or not. next is to turn up the pressure some more and see what happens.
heres the log the pull is around 566 second
the vgt setup just feels sluggish to me , its slow coming on it doesn't hit hard. The car does run good when you hit full pressure.
Cant wait to turn up my timing, my turbo is flowing 50lbs min and im getting 412awhp out of it at like 5 or 6 degrees timing on pump.
sorry for getting off topic there, turn up the boost tell you see knock and then bring it down a little or reduce some timing. That will get you some more power.
