Having small issues with 95 gst
95gsttsi
132
Aug 20, 2010
Sturgis, Michigan
First off when i start the car, it likes to rev up and down before it warms up.. now ive adjusted the throttle cable, it has helped but continues to do it..
i also have coolant issues.. my coolant level stays the same on my guage but my motor is gets really hott when i do tests.
another thing is my gas gauge says 1/4 of a tank and my gas light comes on. could my gauge cluster just be bad?
What do you mean "do tests"? The stock temp guage, like the boost guage is very uhh inaccurate. Unless your very low on coolant and are overheating, its going to stay right about in the middle. And I dont know about you but, 185-210 degrees is pretty hot to me! haha! :p
-sounds like the IAC sensor which you could try cleaning it but most likely you'll need a new one. unplug and see if it idles up.
-the sending unit in your tank could be bad.
-the stock coolant gauges are in accurate get an aftermarket one.
Your Idle is "Hunting / Surging", Check the following.
http://www.dsmtuners.com/forums/articles-engine-fuel/191137-how-fix-your-idle-surge-problem.html
^agreed on the coolant, you may be low on coolant, or have a bubble in the system.
* do this on a cold engine*
1. Remove radiator cap.
2. Start engine
3. fill with coolant/water/beer
4. Let the engine reach operating temp
5. Visually look to see if coolant is flowing, if not check thermostat.
6. once you see flow finish adding coolant to top off.
7 replace radiator cap, and refill reservoir when engine returns to cold.
2. Start engine
HAHAHAHA!!! You know someones actually going to try this right?! I can see the post now!
"I put beer in my coolant, engine wont start?"
But I agree with checking the IAC with a volt meter.
