Having clutch problems...
schlosra
Feb 7, 2008
Dayton, Ohio
Not exactly sure if its the clutch, but something along those lines. When im driving on the highway, say 60-75 mph, its like the clutch pops out just a bit and the car starts shaking pretty bad when you try to accelerate. The a/f guage goes completely lean during this time until you hit the gas then it lights up almost all the way around kinda spiratically goin nuts. If i press in the clutch and let the motor wind down to idle then release it the problem go's away for a bit but eventually starts again. If im under 55 it wont do it and if im putting a load on the clutch driving 85+ it wont do it. Ive bled the clutch and adjusted both the rod and upper stop but to no avail. New slave with 100 miles on it and master with 3000 miles on it. The master was a knockoff if that could be my problem. Clutch holds fine no slippage at all. Anybody have any ideas?
Thanks for the help.
:thumb:
I was told it has a six bolt, didnt have any proof though and i havent checked. Its not throwing any codes unless the light burnt out.
