Haveing problems with my Auto Meter Tach
OR Talonted
38
Jun 13, 2006
Carrollton, Texas
First of all let me tell you what kind of car, it is a 92 Talon TSI. I just installed a Auto Meter Tach. I wired everything correct. I wired the tach signal wire straight to my ECU which alot of you told me it was the number 21 pin which is the cam angle sen. Well when that wire is hooked up my car wont start and when i disconnect it it starts just fine. I was woundering if anyone has had the same problem and if so what could it be? Also if you know of anywhere else to splice into. I also tryied the white wire on my transitor.
i spiced mines into the white wire of the actual cam angle sensor coming off the valve cover but the problem is mines doesnt read right, the rpms on the stock gauge will read like 4thousand while the auto meter tach reads like 2, its always lower than the stock rpm gauge... I never had the motivation to figure out why its like that our wire it to the right wire, but it still lets me set shift points, but to be honest I never use it or even look at my tach anymore its just something else sitting on the dash LOL... I dont know your questoin though never ran it to the ecu.
because i have a little problems seeing my original tach so i wanted something bigger. Pluse a hate glasses. I know sounds pretty stupid.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
