haveing a problem with my new coil on plug setup
matt1995tsi
Jan 13, 2007
alto, Georgia
ok i bought a coil on plug setup off ebay and i hooked it up the way the direactions said to and im not getting any fire to the spark plugs i even went as far as grabing the spring tht gos to the coil pack, it shocks me but no spark to the plugs its not a connaction issue ive already verifyed that so im stump. please help. matt :talon:
Double check your wiring. Did you wire in your tach box from the coil? With out the two extra little devices on 90 coil packs your plugs should fire but your tach will not work.
i double check the wireing more like i triple check it still nothing, the first time i wired it up with the tach box but after it didnt work i pulled it back out and took it off thinking that might help. matt :talon:
