have you heard about this stuff?
WhiteNight92
Oct 19, 2009
Pekin, Illinois
Have yall ever heard of Steel seal. we are thinking of using this and if it doesnt work we get are money back, but i was wondering if any of yall had expirince with this stuff thanks if you have.
Lots of stuff on a web search about it, sounds like the average load of shit you get with any stopleak product.
If you have a leaking gasket or seal, the only fix is to replace it. Don't make your work harder when it overheats and fails.
End of story.
I have got to agree with the post above, just take the time and do yourself a favor and fix it right.
I have used it on other peoples vehicles several times. None of these were turbo'd . There is a process of draining & cooling that cures the sealant. It did work on the cars I treated. I never heard any negative feedback. It is a band-aid type fluid that will work on most applications. I would not even think to fix anything with any cyl. pressure with witch oils. Tres...
thanks guys for the input. im looking for a quick and easy fix for the time being once a get my sata paint gun sold i should have the money to buy a newer 2.0 dohc for my eclipse but for now i need my car to get to work and school. it sucks not having a vehicle going to college in a different state. i have a non turbo so im going to try this and see if it works for now untill someone buys my paint gun so i can buy a new motor.:hellyeah: thanks for all your help tho yall.
Ok, so if you try it , do some prelimanary stuff and you probably will have luck. If there is lots of crap in the overflow tank for the radiator you shoul do a flush of the system with a cleaner prior to going to the sealant process. Make sure to run the heater on hot to expose the whole system. Being non turbo is a plus in this instance. :) Tres....
I wish the best for you, let us know how it turns out... :thumb:
A quick fix that is not quick! Do it right the first time! There are no short cut, just more headaches later on down the road.
