Has anyone ever seen anything like this?
shockey1013
118
Sep 21, 2008
Colorado Springs, Colorado
Well I was putting a new starter plate one car and pulled my pressure plate off and this is what I found. This I a brand new fidanza 4.3. Only about 1k-2k miles on it. Could this be from improper break in? Thanks.
Based on the wear patterns on your pressure plate I can tell you were fairly easy on it. Were you ever stuck in extended stop/go traffic with it? You might want to contact them with pictures of your pressure plate, flywheel and disk friction surfaces for a warranty claim. It could also be subpar lining material or the adhesive was noncompliant.
It is common to see this problem, but normally from excessive stop/go traffic or moderate to extreme abuse.
Tim Zimmer via Evo Phone
The same thing happened to me back in 2009 after 3000miles, except mine was the F1 Racing Clutch ($130 on ebay). This is what I was told by Jack's transmissions " I think when it comes to single disk units, 4 or 6-puck unsprung is the way to go." http://www.dsmtuners.com/forums/drivetrain-tech/336469-im-never-buying-clutch-again.html im not sure why the pics are gone on my thread when they are still on photobucket
Yes I was def easy with this clutch. I've actually never launched the car yet (3 months on the new awd chassis). I would try and contact Fidanza but.... When I bout the shell, this clutch was brand new never installed Sony don't have a receipt or anything.
Thanks for the link Shredwin. Had some good info in there. Mmmm twin disc would nice hmmm
  • Wanted 6 bolt NT water pipe
    • chrisman287
