Harmonic balancer pulley
Here on the classifieds or from the parts store or ebay. Anywhere practically. But they range from 50-120 bucks. Unless you get a really sweet one.
If you're looking for a replacement, you'd might as well look for an after-market one because they cost the same.
Look around for unorthodox.
Do not get a solid pulley.
Get OEM look on extremepsi.com or maperformance.com those are the two vendors I deal with and will not do you wrong.
I would reccommed OEM or Fluidyne(which is really exspensive) but The aluminum ones work okay but they take away the fact of what a HARMONIC BALANCER does. Just search broken crankshaft and most of them are running a solid metal pulley.
I phail. :(
You have 3 choices. They can be found through one of the site's supporting vendors. And I personally would not buy a used dampener.
OEM - cheapest of 3, but known to fail
Fluidampr - more expensive than OEM, proven to work
ATI - most expensive, proven to work
This topic has been covered way too many times.
