96-2g-talon
- 0
- Apr 19, 2012
Butler,
Pennsylvania
I'm new to the 4g63t have some experience with the 420a but this has me stumped. Just bought this 96 talon tsi the kid i got it from didnt know what he had so i got a good deal. currently the car has the following mods hard piping for the ic, corld air intake, and tb also has aftermarket intake manifold, 3" down pipe and exhuast with a high flow cat, o2 dumped to the atmosphere. So when i got it it was running ruff but i knew it to be from all the vacuum leaks and open lines that the kid hooked up correctly all the above work was done by his mechanic and was given reciepts for it except the vacuum system which he tried to do on his own. So i get it home eliminate the evap and egr systems correctly with the ports on top of the tb capped, new lines for the bov fuel pressure regulator and turbo wastegate set up all per the chrysler dealer diagram. It had a few CEL that i took care of correctly by replacing coolent temp sensor, fuel pressure sensor, and manifold differential pressure sensor. Now im still having trouble getting it starting and once i get it started after about 20 trys i have to let it run for 5 minutes before i can even drive it. But once its running it runs like a raped ape. The only other problem is it idles around 2k constantly if its in gear with the clutch in or out of gear with the manual gear box in nuetral..........
Now my big question after that lengthy breakdown is could all this be caused by a simple boost leak or do I have a nasty little gremlin somewere else that i need to track down. I'm almost at my whits end with this car. Can anyone help I really dont know were to go from here except a boost leak test and compression test but what else???? Thank you so much in advance for your help.
