Hard hot start. ecu?maf?FI rings?sensors?
Daaan
229
Aug 15, 2007
Courtice,
I already searched.
I have problems starting my 1g after its been running for about 2 months now. When i try to start it, it sounds as if its running on 2-3 cyls, turns over for about 3-4 secs @ 500rpm and dies outWTF. If i turn the air con on so the fans activate, it will cool down and start faster. It starts 1st try no problem when its cold. PLEASE HELP ME :cry:
Heres a list of things i have replaced..
1. injectors
2. maf
3. fuel filter
4. vac lines
5. plugs
and probably more just cant remember.
thanks everyone.
Make sure you have the plugs gapped right and you have the spark plug wires set in the correct order so the coil pack is firing to the correct cylinders.
Thanks I will double check those. When it starts it will run great and drive good until i turn it off. If i turn it off, then turn in on right away it will fire up right away. when i let it sit for 2-3 min then try to start it will bog and die over and over again for about 3 mins. then it will start.
the 1G ECU have many problems because the capacitors leaks. i have 4 ECU in my house. all have leaked Capacitors.
Does anyone know what resistance should show up on a voltmeter when i check the coolant temp sensor? and at what temp it should be for that voltage
And its been doing this since the last owner owned it too. So i was thinkin if it was the ecu i would think the caps would have leaked out enough to destroy the board already.
