Hard downshift
DanGST
352
Oct 8, 2010
Bronx, New York
I had my transmission rebuild a while ago. But over the last week my solenoid connector came lose so I had no 1st 4th or OD. I reconnected the connector and now my car down shifts hard to the point it makes a clucking noise and jerks forward. What can be wrong?
do you rev match? and if its making a clunking noise, something could either be loose in your differential, suspension, or transmission
Everything is stock. Problem was found the bolts on the cross member were lose giving the transmission room to move
And remember the Fuzzy Logic of the transmission, it learns how to shift... bla bla bla... but if you have run without the speed or load sensor, maybe the ECU learned wrong parameters... I thing reseting the ECU could help...
