hahn 16g price?
jbark
115
May 11, 2008
Reading, Pennsylvania
so i found a local guy that has a hahn racecraft 16g with manifold for the 420a and he wants only $150 for it. if its mint and no shaft play is it worth the hassle to get a 4g63 t3 manifold and an o2. also if its got shaft play is it still worth it to rebuild. lmk, jeremy
A Hahn Super 16G is nothing more than a Small 16G cartridge with a different compressor cover and a 10cm2 T3-flanged turbine housing.
The 10cm2 T3 turbine housing isn't a good idea for a low-compression 4G63; you'd be better off swapping that housing in favor of a DSM bolt-on turbine housing and using your existing manifold. The compressor cover that comes on the Hahn 16G makes it rather difficult to run an internal wastegate actuator as well....there's nowhere for the actuator to bolt unless the compressor outlet is facing upward toward the hood of the car.
+1:thumb:
So I should find a 16g compressor side and I'm set. Is the 150 good and worth it.
