GVR4 motor in 1g Eclipse...PS belt difference.
lgnd6
Feb 20, 2009
850, Florida
Ok so I have a 1g GSX. From what I am told it has a GVR4 motor in it. I know its a swap, as the serial numbers do not match. In addition, I have the cylcone intake manifold which justifies the claims of a vr4 motor.
I was also told that the power steering pump was out which is why it was bypassed.
After inspecting the pump, and the rack/pinion, the pump seemed fine. However, the pulley for the power steering pump uses a v-belt style belt where as the alternator, ac, and crank pulley are all the flat style belts.
I began to think that maybe the reason it is like this is maybe the USDM 1g uses the V-belts and that the GVR4 motor uses the flat belts which is why it was bypassed in the first place.
However, when I bought a new alternator yesterday for the car (I bought it for a 1991 Eclipse GSX) the alternator also used the flat style belt.
Is it possible to remove the power steering pulley and just replace that as like I said the pump seems to be fine.
I've searched for aftermarket underdrive PWS pulleys but didn't find much that I would trust.
What are my options?
Don't say just don't run power steering, or swap for a manual rack. Thats not what I want.
well I'm not too fmiliar with the slight differences in the motors but I would suggest youo just try to find a 1g p/s pump and the bracket if needed. I'm sure you can probably find on at a pull-a-part or something similar.
I would love to try and help you out here, but this part confuses me greatly.
You are saying that the power steering pump you have in your car has a pulley for a v-belt, correct? If that is the case, that is not the problem because that is correct for DSMs. Answer me that and we'll go from there.
1g's use a v-belt for the P/S. All the others are sepentine (flat-style) belts. The water pump pulley is divided for both the P/S v-belt and ALT. serp. belt. The water pump pulley drives the P/S belt with the rear divided section. All you need is a v-belt for the water pump to P/S.
Okay, so the dsms use a vbelt for the power steering pump. It runs to the water pump and its on a seperate drive belt than the rest of the accessories. I will look at it again, and try to find a schematic for the belt routing because it looked to me as if all accessories would be driven from the same belt.
Thanks.
P.S. the reason I thought maybe it was differences in the the two vehicles is because there was alot of stuff not hooked up because of slight incompatiblilities. I figured maybe this was another.
