1G GVR4 coilovers on a 1g
No, they won't fit without modification. The front top hats have a different bolt pattern. The rears should bolt up fine.
The brand and type of coilover may play a part in fitment, though. What coilovers are these?
^Basically, depending on the top hat. Some of the camber plates may require cutting and clearancing if you want the full range of adjustment.
