GT35R people, what setup do you run?
anomalyinva
211
Aug 12, 2003
I'm not asking what is needed, I'm asking what you personally run. If you've dynoed it, what did you put down, what gas and boost? Same thing for if you've run it at the track? What turbo did you upgrade from? How is the transitional response on it? I don't really care much about lag, but I guess the rpm range you hit full boost in, as well where do you build 5lbs?
Slowboy put down 539 or so WHP with there bolt on GT35R. Look at dsmtimes.org and you can see what other GT35R's have run.
AMS put down 613 with their bolt on gt35rl and they have the fastest spooling unit on the market.
The GT35R is an amazing turbo.
640whp and 565ft/lbs on my car @ 40psi on a stock ECU.
549awhp and 440ftlbs on one of our customers builds, on 98 octane pump gas at 26psi. (Craig's White EVO)
Nate
SBR
at 30 psi...with an exhaust leak, and a shitty tune (only 12 degrees timing advance), LOL ...we made 552whp on my car.
Its a gt35r with a 1.06 a/r.....im sure next tuning session we will easily break 600 plus to all 4 wheels.....yeh its laggy, but you learn to deal with it
You can check my profile to see the rest of my mods :thumb:
What housing is everyone running? I've heard some problems with compressor surge on the S housing above 25psi.
I had surge problems on my 60-1 with the S cover, but only above 36psi. Haven't hit the surge limit on the 35R yet, even at 42psi in the TO4E cover. I would still recommend the anti-surge cover to anyone that purchases one however.
Nate
SBR
