GSX vs GST clutch plate
jason6989
Apr 21, 2013
Manama, Arizona
I was wondering if i could use a GST clutch plate on my GSX, i heard the GST flyweel is 1/2 inch bigger then the GSX Flywheel
clutches are same, you chould check out southbend clutch they're pretty good and inexpensive
I'm not gonna say parts suppliers are always right but you could just look up a part you need through a part supplier just for research because many times in the application section it will tell you what all it will fit. Summit racing usually has a decent applications section to check out. I've used it several times just for cross reference of part numbers or what cars parts are the same to other models.
Now buying a clutch or pretty much any part I would look to the supporters of this site. Don't want to bite the hand that feeds.
