420A GSX fuel rail to RS
ion12
Apr 21, 2023
Paramount, California
Hey guys
Hopefully anyone can help me out with this. Is it possible to convert the fuel rail for a gsx or gst to a rs or gs. Looking at the part it looks possible if I can find a way to block off the stock fpr that goes on the fuel rail or would it even fit correctly? Any help is appreciated.
If you really need an upgrade, just modify your 420a fuel rail. It's probably less work than making a 4g63t rail fit. Use the pressure test fitting as your supply inlet. Remove the Schrader valve and drill the hole a bit larger. The threads can mate to a female AN fitting, I'm forgetful if it's an 8 or something else. You'll have to weld closed the stock inlet hole. You can run a braided AN line from the underbody hardline all the way to the threads on the fuel rail to eliminate some restrictions.
Some years back you could buy a billet aluminum VMS fuel rail on Ebay. I've never seen one in person, but would imagine they aren't the greatest quality at a cost of 60 bucks or so. It's probably something to sit there and look pretty but not really an upgrade.
Depending on your engine's fuel requirements, a fuel rail modification/replacement may not be necessary. If you get a stronger fuel pump and some way to actively control fuel pressure, enough fuel can probably be shoved through the stock inlet. You'll have a few other things to upgrade if you're outflowing the stock fuel rail.
