gsx dies while driving
Meinleat
57
Feb 19, 2012
Klamath Falls, Oregon
:hmm:ok so i just got my dsm back from the shop and this is the first its been running in about 2 years the check engine lights constntly on and im not getting any code from the ecu also while driving it dies accasionaly its hapened twice so far and it seems to happen arround when i start to push in the clutch so i can coast to a stop the fuel system is fine new pump injectors etc. and im starting to think that it might be just a really touchy clutch anything helps so thanks
So it dies a when you push the clutch in to coast? Rpm's drop and just dies instead of mellowing out for idle?
Check and make sure your idle screw isn't turned all the way in.
It mostly stock just oem replacements on most things it has a short shift and its lowerd thats about it did a boost leak at the shop and came back fine idling it sits around 800 to 1100 but its normally steady unless cold and it does have a recurculatory bov
I will check the screw when the suns up in a hour or so
No idea then i was thinking was cylinder head
Your egr valve is on the side of your intake manifold underneath the throttle body. If have a vacuum tester you put it on it and if its working it will make your car run bad while idling when you open it. If you don't have one get a vacuum line and put it on the egr port and while idling attach it a vacuum port on the IM. If its working it will make it run bad when you give it vacuum(opening the valve) and go back to normal when you take vacuum away(closing the valve). Have you checked the idle screw?
It actually ended up neing a injector leaking thanks to a split o ring and just spraying every where
Ahh yes that would do it for sure. Glad you got it fixed. :thumb:
i don't think it has anything to do with the clutch . you are taking your foot off the gas and going to the clutch now the engine doesn't maintain an idle so it dies. i would try fixing the check engine light first its on for a reason .
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
