gsx build
Boost_addict
Nov 25, 2009
jacksonville, Florida
building a 97 gsx
putting in a built 6bolt stroker
with a 1g trans
just got the motor/trans in there
had a couple minor questions
1 will the 2g drivers side axle fit in the 1g half shaft?
gonna be running 550cc injectors, can I run these with stock setup?
will a 94 gsx 3" down pipe fit with this setup
any help or advice would be accepted
i didnt think you could put a 1g trans in a 2g because of the mounting differences?
without someway of controlling your injectors you will have running issues thats if it will run.
