gst with mods what Should I run
troysevo16
96
Jul 29, 2004
spencerport, New York
Hey Guys, Just woundering what I should be running well here is what I have for mods: evo16g ported and 34mm flapper, greddy big fmic, slowboyracing vrs full 3 exhaust system (no cat), mbc boost controler, 660cc injectors, 3 inch intake pipe with cone filter, afc, act 6 puck disc and 2100lbs clutch, hks bov, ported intake mainfold, removed ac, boosted gauge and probably all other saporting mods just cant think of them right now. Oh and by the way my car is a 97 gst I have run 14.2 @100 but my best trap speed was 104.5 and this was before I had the turbo ported, enlarged flapper, and ported exhaust manifold and was running between 10 and 12 lbs of boost. One more question do you guys think I can beat a 90 mustang gt with gears, cams, exhaust, headers, and a t5 tranny?
sorry forgot a couple of things I just remembered evo 02 housing (ported) and 255lph fuel pump, come on no one knows what I am saposed to be running? I find that hard to believe.
Too bad you find it hard to believe. Do you expect every car with similar mods to be tuned the same and then driven the same, in the same conditions...resulting in the same timeslips?
All you can do is some comparisons, but mainly get the #### off your ass and take the car to the track. That will tell you what you run.
I have similar mods and have run a best of 13.68 @ 107, highest trap is a 13.7 @ 111.
Street tires, stock suspension, evo3 16g @ 25 psi, falling to 20, c16 race gas.
-T
    • Sdcryan1
