gst vs 420a exhaust
cubedmayhem
94
Sep 7, 2003
kirtland,
Hey I thought that gst"s dont share the same catback as the 420a. Latly I have heard differently, but I dont consider them reliable sources. Can anyone clear this up?
No_Skillz said:
If you look at the two cars in their stock form, the turbo model will have twin exhaust tips, the naturally aspirated will have a single.
The tips are on the muffler and have nothing at all to do with the path the exhast takes to get from the motor to out the back. As all I have been exposed to is the turbo, I could not say what the difference is between the two, except that a 3" exhaust on a N/A would not fly.
Jim
The 2G GST and 420A exhausts are routed the same, and the use they same hangers. That's how so many 420A guys use GST exhausts as a cheap upgrade.
The only differences between the two exhaust systems are at the cat, and obviously the downpipes are much different.
I don't think the performance gains are that appreciable though (unless you're talking about buying an aftermarket GST exhaust). If I remember correctly, the GST has a 2.25" exhaust, thus, the only difference between the two is a better flowing muffler.
No_Skillz said:
You guys are missing the point of his question. He wants to prove to friends that the catback on the 2 cars are different.
Ok... then they're not, except for the mufflers.
actually i just may have been proved wrong. I kinda was talking about the piping, I really word that wrong. I knew the diameters would be different, but i thought that the piping was different. So in reality you COULD take a gst catback to the 420a and it WOULD have proper fitment?
Yes, many NT's use it for a cheap and effective upgrade. A 50$ stock exhaust is very effective and since it is NT anyways, does plenty for the motor.
Yep. Everything will match up exactly. Even the pipe diameters; as far as I know, all models (except the GSX maybe???) had 2.25" pipes. The only major difference between the GST and RS/GS is the muffler.
Don't know if the GSX had different diameters, but I know it was routed differently. Since both engines were the same setup basically, I would assume the size was the same for GST / GSX models, but I am not positive.
The cat-backs are routed the same between the turbo and n/t models. The actual design of the exhausts are different with the turbo exhaust having a larger diameter. The two exhausts are interchangeable.
The downpipes are obviously different.
The diameter on the GST/GSX are the same but the path is different due to driveshafts and the rearend. As for the 420a, the body molds for all the models are the same so other than the dp/muffler and i think the diameter, the path is the same from the cat-back.
So I think we all came to the conclusion that...Yes...the Gs-t and 420A have the same diameter piping and take the same route as far as piping goes...with exception of a dual tip muffler? RIGHT? OK cubedmayhem... I think that is your answer unless you mean something else? Go and tell your friends off now. Good luck. :thumb:
i HAD BEEN MUCH INFORM!!!!!! I geuse that i lost that but a 12 pack each should make them HOPPFULLY forget bout it and not remind me. Hearing all different aspect of how they differ was relly goood feeback,but the question was piping. if it was the same. aslo should have made commit aftermarket wise would a catback for 420a fit corectly on
gst [ ex. cat].so this could be a;ll that is need needed:dsm: :dsm:
gst [ ex. cat].
Yes... they're identical...
An Apex'i N1 catback for the GS-T Eclipse will bolt right up to an RS. Similarly, a Tsudo catback for the GS will fit on the GS-T. It doesn't matter what model you have, so long as it's not the GSX - other than that, all exhaust components from the catalytic converter back are interchangeable.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
