dsmking101
- 224
- 2
- May 13, 2009
Utah
hey guys can a gst fuel pump work on a 420a turbo will it work well and be safe to run boost with the 420a...thanks guys
If you were using MegaSquirt, then these would be options.
Also if your not going with some special engine management like these guys are suggesting DEFINATELY upgrade to a SFMU. With an FMU you can tune your rising rate like the FMU but you can also adjust your static pressure so you can run bigger injectors and still have them idle like stock. Right now my RS is running 22psi FP and 10psi of boost at I think 10:1 rise (I think I forget). Then you can use something like a SAFC to fine tune your AF ratio. It works pretty well but there's a limit to the size of injectors you can use and still be able to idle with such a low FP.
