Gst Eprom Will It Work For A Gsx???
TiradoCC
378
3
Dec 17, 2006
Seguin, Texas
will a eprom ecu from a gst work for a gsx????
Yes sir, any 95 Eprom Turbo ECU will work in an 2G turbo dsm, assuming your going to use it for DSMlink. A GST 95 eprom ecu will drop into a GSX, but it will add the speed limiter I believe.
If swapping into a 97+, the 95 Cam angle sensor single is inverted, but can be changed if you run dsmlink.
ok i wasn't sure but i wanted to make sure because i am selling my eprom....thanks so much for the info
I believe the GSX ecu in 95-99 also does not have a speed governer. So if you install a GST ecu in a GSX, your speed will be governed.
Will work, and speed governor will be removed since the AWD cars came without the speed governor from the factory due to their tires...
I understand that a EPROM ECU from a 95 will work for any 2G, but is installation just as simple as plugging in the ECU into the car with no other tuning?
